Released in North America in November 2006, the Wii was Nintendo's first home console to directly support Internet connectivity, supporting both online games and digital distribution of games and media applications through the Wii Shop Channel.
288 Questions View all
What happens if you plug in a 110v wii into 220v?
I have an American Wii, its 110v and I moved to Saudi Arabia and I accidentally plugged it in without a converter. It made a lot popping sound and even when I plug it in a 110v converter it would not work so I opened up the power brick and saw some small yellow stains on the board.
Score 1
Add a comment
1 Answer
Most Helpful Answer
When you connect a device to a voltage higher than it’s rated supply voltage, it over-stresses the circuit inside the device. By doubling the voltage from 110 upto 220V you have also forced through much more current into the device. Chances are that 2 x voltage blew some components inside before the excess current would have over- cooked the the circuit inside. If a component has stained the board, chances are that’s what got stressed and broken down inside. The yellow stains maybe insulation from a component or transformer indicating the defect component. An electronics repair shop maybe able to help or seek out a replacement power brick? Hope this helps?
Score 1
1 Comment:
My cousin used to burn out her American hairdryers on UK mains supply all the time until she bought one specially to use in the UK and Europe.
by
Add a comment
Add your answer
yusuf ahmed will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 22
All Time: 2,539
