First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
130 Questions View all
Backlight completely gone after small bump
Small drop about 5 years ago gave up on it since apple quoted me very expensive repair cost, saw a video on an easy repair for backlight and thought it was worth a shot, would be nice to get it running again. Was thinking the small bump could have disconnected backlight somehow as i doubt a small bump like it was could do any major damage, when powered on could hear the audio on ipad fine and touch screen worked just completely black display.
Add a comment
1 Answer
Chosen Solution
To test for this, plug your device into a charger or an iTunes enabled computer. Then shine a bright flashlight on the screen. If you can see a dim image, then the backlight circuit has been damaged. If you can’t see an image at all, then it may be the LCD circuit that is damaged.
In both cases, it’s either the actual LCD or the circuitry. Either way, those are both repairable but the board-level repairs are not really DIY unless you are already experienced in micro-soldering repairs.
Score 1
Add a comment
Add your answer
Joseph Hunt will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 46
