Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
97 Questions View all
iPod not syncing to iTunes. New battery. Swapped HDD with compact SD.
I have a 3rd gen classic iPod. Replaced the battery and swapped out the original hard drive with a compact flash memory card. When I plug it in to my computer iTunes does not recognize it. The screen shows the Apple then the drive with the “!" Does this mean the cable and/or the logic board are bad?
Add a comment
1 Answer
iPods will not sync via FireWire after the hard drive is replaced with flash storage. You need to use a Y-cable to sync it. One end should be plugged into a FireWire charger, and the other end into the computer.
Add a comment
Add your answer
Seth Aronson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 78
