Repair guides and support for the EOS 70D, a DSLR camera released by Canon in 2013. This camera can be identified by the model number DS126411.
66 Questions View all
Camera works with battery grip but not without it?
After buying brand new Canon 80d I have bought third party battery grip. Camera was working more than fine with battery and battery grip. After removing grip camera can not work without it? Probably it is because of using third party accesssories but in my oppionion it should not be a problem. Is there any fix, what should I do. Also important information is that I have been using third party batteries and that the camera was sending the info that I might be using not genuine batteries?!
1 Comment
Add a comment
1 Answer
Most Helpful Answer
The thing with genuine batteries is that they have a charge controller inside them that helps to safely turn off camera if such need occurs. If non-genuine batteries aren’t really cheap and from reputable brand, then it shouldn’t be really much of a problem. If they are, than it might be that camera doesn’t get enough current to start.
A million dollar question is: Does 80D launch with original battery?
If not, that it seems like your battery grip could break something inside of its battery section. After all, chinese guys didn’t adapt their grips for 70D to be usable with 80D, since LP-E6N and LP-E6 are “officially interchangeable” (even though LP-E6N is similar to LP-E6 in terms of looks and shape, there were minor design changes to LP-E6N under the hood, that could do something to your camera, imo).
Score 1
Add a comment
Add your answer
Harun will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 716
