Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
97 Questions View all
Beats Headphone Jack stuck
The headphone plug was bent a bit, when I went to put the plug in it went in swiftly and then when I pulled it out, the beats solo 3 headphone wire cord plug got stuck. I have tried everything and nothing has worked. Is there any way that I can get it out. I have the Beats solo 3 and The Ipad is the Ipad mini 6th generation. And when I go to listen to music without the headphones no sound comes out because the ipad registers it has headphones on
Score 1
Add a comment
1 Answer
Hi,
If a portion of the headphones are stuck in the jack you can try to delicatly remove them using this tool GripStick Headphone Plug Extraction Tool . However you need to be careful doing thiis. If you cannot remove the jack using this method then the headphonje jack would need to be replaced which is this part iPad mini 4 (Wi-Fi) Headphone Jack .
It might be worthwhile seeking out your local repair shop if you do not feel you are able to preform the repair yourself.
Kind regards
Matt
GripStick Headphone Plug Extraction Tool Image
Product
$19.99
iPad mini 4 (Wi-Fi) Headphone Jack Image
Product
$9.99
Add a comment
Add your answer
Not Brendon Urie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 222
