Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
55 Questions View all
GBA turns on but has a blank screen and no audio
Hey everyone,
I recently acquired a broken GBA that initially didn't turn on at all. After doing all the normal cleaning up corrosion on the battery contacts, unjunking the power switch with IPA etc it now switches on, as indicated by the green LED, but nothing shows on the screen at all. I even hear a bit of noise from the speaker, so I know that works, however, it's just the *bunk* sorta sound you hear from turning the console on - there's no sound from the game or startup sequence. I should add that I hear this through the headphones too.
I've checked the ribbon cable connecting the screen and logic board and nothing seems amiss - I've also thoroughly cleaned both the ribbon cable connector and slot with no luck.
Any ideas?
Add a comment
1 Answer
Chosen Solution
This problem was fixed by giving the board a thorough going over with white vinegar. I'm not sure where exactly the problem was as there wasn't too much corrosion overall, but I'm not complaining.
Add a comment
Add your answer
Brendan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 61
All Time: 2,475
