Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68 Questions View all
My iPod won't turn on or sync PC, turn on with power adapter
Hi,
sorry for my English
my iPod nano 1gen has a dead battery and it turns on when plugged with power adapter but it doesn’t turn on or sync when plugged with a PC, it shows only the screen of low battery.
If it was possible, I would use it without substitute the battery, but I would be able to sync in order to change the music I have in.
I tried with a cable like this https://images-na.ssl-images-amazon.com/... but even if I could turn it on, it isn’t recognized by my PC…
What can I do?
I have another question, does this iPod compatible with Audible (.aa or .aax) audiobooks with DRM?
Thanks
Add a comment
1 Answer
Most Helpful Answer
I don’t understand how use are using that cable on your mini as it doesn’t have a USB 2 port. Please look at this and tell us if you have the correct cable to either charge or connect to a computer
https://support.apple.com/en-us/HT201545
Also why haven’t you changed the battery out? I understand that it is very difficult repair. Here’s how to do it:
iPod Nano 1st Generation Battery Replacement
Score 2
1 Comment:
Thank you for your answer,
I have a normal charging cable (30 pin to usb), and I connect the 30 pin to the iPod and the USB port to the female of that cable, then I connect two male usb to PC in order to give the iPod more power. I did this because I thought that if I can turn it on with USB power adapter and I cannot turn it on with PC is because a USB of PC can't supply enough power. Then I use that cable which normal use is for external hard drive that needs external power supply. But I can't sync even if it is switched on.
I haven't changed the battery yet because if I could sync without substitute it, it would be ok for me to use the iPod only connected to AC. Otherwise I would be sure that it can read read Audible .aax audiobooks before substitute it.
Thanks
by
Add a comment
Add your answer
Alex231 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 10
All Time: 151
