Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Questions View all
Can I repair broken IR and Fan connectors - sheered off at logic board
I have a Mac mini mid-2011. I installed an SSD as the second drive.
It works but I have broken the IR and Fan connectors - sheered them off at the logic board.
Is it possible to repair these two connectors with “micro-soldering”?
What tools do I need to do that please?
Add a comment
Most Helpful Answer
@cooker47 that will depend on how they are broken and if they destroyed the solder pads. If so, you will most likely have to run some jumper. There are no schematics or boardview for the Mac Mini so that would mean it could get tough. If the pad are still decent, you can resolder the connectors (or buy new ones if the originals are destroyed). Take a look at the answer I popped off the fan connection from the logic board...Fix? and see how to solder it. Different connector, same idea. Post some images of our damage so we can see what you see. Adding images to an existing question
Score 3
Add a comment
I would directly solder wires to motherboard
Score 1
Add a comment
Add your answer
Michael Cook will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 243
