The Keurig model K70 is a beverage brewing system for home and commercial use. The Keurig is made by the American company Keurig Green Mountain.
26 Questions View all
Not Brewing full cups or any water period!
The only time my Keurig brews is if I hold the overflow holes… it's like there is no pressure. Also it says de-scaling and idk what that is... Please help me I literally watched so much videos on YouTube…. Clean the needle… all that stuff they tried…
2 Comments
Thank you for the suggestion here is the things I did so far…
White Vinegar (diluted just a little)
Clean everywhere
Force water through the thing with a turkey baster
Used compressed air to try and flush it out.
The only thing that helped any water come out was to cover the holes on the overflow valve…
by
So I found a walkthrough that deals with the vacuum system which could be your problem. How to Keurig K75 Platinum Brewing System
Good luck!
by
Add a comment
1 Answer
Chosen Solution
Descaling removes the white stuff that builds up inside your coffee machine. As the machine heats the water it causes some of it to evaporate and leave minerals behind which will cause your problem. Descaling is what you need to do to fix it.
Apparently, Keurig sells a descaling solution, but you can also just use vinegar.
https://m.keurig.com/descale-instruction...
Score 1
Add a comment
Add your answer
Wehi & Ricky DeMello will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 74
