The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 Questions View all
Why wont my car crank?
Parked car at work, got done with work, all dash light came on normally, turned the ignition to start, nothing. Towed car home, replaced entire ignition switch assembly, let the car relearn, nothing. jumped the pins on starter relay starter cranked, replaced relay, nothing. Any Ideas????
Add a comment
1 Answer
Most Helpful Answer
Sounds like it must be open wiring between ign. switch and relay somewhere. If automatic trans it may be the interlock switches that prevent starting except in neutral or park positions (typically). I would try jiggling the shifter first to see if it will help get a complete circuit to your apparently good relay.
Score 1
Add a comment
Add your answer
David Lindorff will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 56
