1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Questions View all
MacBook water damage - fixed, but keyboard still not working
So long story short, I spilled a small amount of tea on my MacBook Air.
I followed everything in the guides and videos I found online - removed battery, put the Mac upside down and let dry, took it all apart and cleaned each component carefully with isopropyl alcohol, let everything dry and put back together - and now everything works properly EXCEPT the keyboard. I plugged in a usb keyboard to test it, and that worked fine.
The only thing I didn’t do in my repair attempt was actually remove the keyboard itself. I got as far as taking the backlight panel off, and I even removed the like 50 screws of the keyboard, but I couldn’t seem to get it out without damaging it so I left it.
Does anybody have any tips on what I should do? Is it safe to remove everything again leaving just the keyboard itself attached to the frame, then soaking it in an isopropyl alcohol bath? Not letting it touch the screen of course.
Thanks for any help!
Score 1
Add a comment
1 Answer
Most Helpful Answer
unfortunately the only way to remove the keyboard on your model of MacBook Air is to tear it off from the top case as there are rivets that hold the keyboard in place. A complete top case replacement ( MacBook Air 13" (Mid 2012) Upper Case with Keyboard ) would be a much easier replacement, but also more expensive.
At this point I would either replace the keyboard or the topcase. An isopropyl bath wouldn’t likely yield in a positive result. If you decide to replace the keyboard I would plug it in before installing it to test that it will fix your issue, and also make sure you remove the keyboard slowly with a lot of tension to ensure you remove 99% of the rivets. You will also need to replace the rivets with screws so make sure you get a pack of keyboard screws as well.
Best of luck and happy screwing!
MacBook Air 13" (Mid 2012) Upper Case with Keyboard Image
Product
$149.99
Score 6
1 Comment:
Thank you this helped for me too.
by
Add a comment
Add your answer
Brad Barnes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 311
