Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
97 Questions View all
Blank Screen after logic board and battery change
Hi everybody,
I am stuck with the reparation of my iPod Classic 3rd generation (model A1040).
I had to change the logic board because a failure and, at the same time, install a new battery for better battery lifetime. I bought both things in eBay. My problem now is that I have a blank screen after the apple logo.
I can restart the iPod pressing Menu button + Play/pause button: the iPod restarts, the Apple logo appears, and then… blank screen.
I can activate the Disk Mode pressing Previous and Following buttons after an iPod restart. The screen shows that the Disk Mode is activated and I can plug the iPod to my Macbook. iTunes recognizes that an iPod with problems is connected and I have 2 options:
  • update the firmware version to a newer one.
  • Restore it.
I can not restore it because iTunes says that I need a FireWire connection that my laptop does not have. However if I try the same operation in windows (with iTunes for Windows) there is no problem and after restore it (or update the firmware version), a message appears for disconnect the iPod of the laptop, connect it to an external power supply and finish the operation.
Then, I restart the iPod to exit the disk Mode (pressing Menu button + Play/pause button), the ipod restarts, the apple logo appears, a progress bar appears and is completed and… blank screen again.
I have repeated the process many times and alwaus have the same result. Something strange is that always iTunes says that a new firmware version is available, so I can understand that the previous attempts to update do not work properly.
I would be very very grateful if somebody could help me with it.
I hope to not lose my loved iPod. =)
Regards
Add a comment
1 Answer
Easy: no flash memory/boot memory. Its equivelant to a paperweight now.
4 Comments:
Timothy, is there any way to restore this boot memory you are mentioning?
by
Could be RockBox.org a solution for this?
by
There is a good chance it will. If this answer was helpful, please upvote it!
by
Hi,
I could install RockBox without problems and it is working properly.
However, if I try to start the original Apple firmware pressing the HOLD swith during the Apple logo, the iPod gets frozen. It is obvious that the original iPod firmware has a problem to boot up
I will continue posting news.
I will be very grateful for any other new idea.
Cheers
by
Add a comment
Add your answer
Basuri will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 154
