Screen is black - can I repair or replace
I have an early 2008 17 inch MacBook Pro with the 1920x1200 Matte Screen. The display is black but the system works fine with an external monitor. Could I just replace the screen or does the screen assembly need to be replaced? I had the spotlights problem for several years on this system which I assume was the fluorescent backlight.
2 Comments
@movdqa describe this "the spotlights problem" a bit more.
by
It was bright at the bottom of the screen with round things and the screen was dimmer as you moved to the top. I was able to use it in this mode for a few years. I think that it was common with this model as I've seen other reports of it.
by
Add a comment
1 Answer
Most Helpful Answer
@movdqa check the inverter first. There could be reasons other than a bad LCD display. This video as well as this should work for you
Score 3
Add a comment
Add your answer
Michael Moy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 35
