HP Spectre x360 13-4101dx - 13.3" - Core i7 5500U - 8 GB RAM - 256 GB SSD
1 Questions View all
HP Spectre X360 13-4101dx Motherboard DA0Y0DMBAF0 - What is this part?
I’ve got a hp Spectre X360 13-4101dx laptop with charging issue. I found that small thing on the motherboard (1st picture), and its original place probably(2nd picture).
Anybody can help me that what the name of it and its function? Thanks.
Score 1
Add a comment
It’s a capacitor. Since they usually unmarked, and the one you have is broken in two, you cannot find out its original value. So you need first to find out the package by measuring the size (width and length, maybe height) and compare to a list of standard capacitor sizes. The size will constrain the voltage x capacity product (ie. for a given size, if you get a higher voltage one, it will have a lower capacity). Then you need to measure the voltage on the pins (most likely a standard voltage like 3.3, 5, 12, 24). Finally find the capacitor with the size you measured, the voltage rating directly above the one you measured (or one higher), and the highest capacity.
Add a comment
A little late, but that part is a surface-mount capacitor.
Add a comment
Add your answer
voneout will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 28
All Time: 1,189
