Second generation of the Ford Focus.
95 Questions View all
Having trouble with a 2007 Ford Focus, what do I do?
Having trouble with a 2007 Ford Focus, getting spark fuel, everything just will not turn over
bumped the coil will not start.
the alarm light keeps flashing ran a tester wire is enabling through the alarm system everything is working but it will not turn over and start but it turns over when I bump the solenoid with the battery but will not start
what could it be tried the ignition switch key and key reader
I tried the ignition switch relay those were good and checked all fuses everything is all good but I think it has to do with the alarm on the car itself
what do I do?
Add a comment
1 Answer
I know this may seem like a stupid question, but did you check the starter itself? Also there are usually fuses and relays underneath the hood, did you also check those?
Add a comment
Add your answer
Harvie Oconnor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 86
