Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
73 Questions View all
The pause menu repeatedly keeps coming up
I have an old Playstation1 and when I was playing Gran Turismo on it the pause menu came up even though I didn’t press the start button, and no matter how many times I press continue the same thing happened again and again. I know there is no problem with the disc seeing as I was experiencing the same thing with Hydro Tunder. I’ve already tried resetting and turning it on and off
1 Comment
It’s probably a problem with the controller seeing as the Analog isn’t working and I didn’t have the issue with my second controller
by
Add a comment
1 Answer
Most Helpful Answer
You might want to try a new controller and see if the issue persists there. Try a different controller and see if this behavior continues.
Score 1
1 Comment:
I agree. The controller might be suffering from a sticky button, and that's usually due to dirt buildup, grime, and possibly food causing the button to stick. A temporary solution is to gently pull the button back out, but the best thing to do is take the controller apart and clean it. Sometimes the membrane pads will lose their strength, causing the 'spring' to cease functioning. If that happens, the membrane pads need to be replaced, or the remote needs to be replaced.
by
Add a comment
Add your answer
AdamsMatthew will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 59
