A one-hand dispensing 12-Cup programmable coffeemaker with an insulated tank and heater that was released on December 15, 2008 and produced by Hamilton Beach.
11 Questions View all
Can the dispensing filter (metal) be replaced on 48465
Hello,
I have a Hamilton Beach Model 48465 (similar looking to 48464). The metal filter where the coffee dispenses is partially clogged. Is there a way of either replacing the filter or deep cleaning the filter?
Thank you,
Jim
Score 2
Add a comment
Chosen Solution
It’s a pain to take care of that because it is apparently non-replaceable. Letting straight vinegar sit in the tank overnight helped the situation. After a couple of years, I grew tired of this process, so I actually grabbed a knife and popped that thing out. Coffee flows normal, however it’s not being filtered (shouldn’t be a problem if you don’t spill the ground coffee when preparing it). I tried going online looking for that little spout part with no luck. You can buy the entire tank part for $20, but really? All I need is to replace this tiny spout (strainer/filter) piece. All in all, the actual piece I removed looks like it was painted with black ink, impossible for anything to filter out through it anymore. I would submit pictures, but I don’t see how I can do that.
Score 2
1 Comment:
Thank you! I ended up getting a new tank. But, I won't do it again.
by
Add a comment
You can pop the filter out and drop it in a cup with equal parts vinegar and hot water to try to clean it. place the end of a flathead screwdriver between one of the three plastic nubs that sticks out of the bottom to hold it and one of the plastic tines on the filter. Apply a bit of pressure and it will flex enough to pop out. I was unable to find a replacement. You can also just take it out and leave it out. Grounds won’t usually be a problem unless the basket is overfilled.
Score 2
1 Comment:
Thank you! I ended up getting a new tank, but won't do it a second time.
by
Add a comment
Add your answer
Jim Koehler will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 6
All Time: 451
