TI-84 Plus calculator support.
39 Questions View all
It does not work..!
I tried to use shift+ sine but i think i accidentally pressed wrong button... Dont know why but after that when i press shift and sine a different screen appears. Then after a few minutes, it does not work... All the buttons (except ‘on' button) dont work....... Please help me. Thanks.
Update (09/19/2018)
Now i can't turn on the calculator....
3 Comments
@hannah00000 Did you try replacing the batteries?
by
Yes. I tried.. But i think it made the situation worse......
by
@thelastmill Hey bud you have any idea whats wrong with this calculator?
by
Add a comment
1 Answer
Most Helpful Answer
I assume by ‘shift’ you mean the ‘2nd’ button?
This issue quite perplexed me, I have no clue how you got to this state, but here’s how you could get your calculator back to normal.
The first thing I’d try is to:
  1. remove all the batteries, including the backup battery (there’s a guide on how to remove it here.)
  2. Hold the ‘on’ button for 10 seconds
  3. Put all the batteries back in (starting with the backup battery).
If that doesn’t work, try it again but, as Aaron suggested, with fresh batteries (including a fresh backup battery)
If that still doesn’t work, you’ve somehow broke something and it may not be a software issue. However, there are a one more thing you can try, an OS reinstall. Now that may sound scary, but it’s not quite as difficult as you’d expect. It’s hard to give you accurate steps in text so I’ll refer you to a video tutorial.
Score 2
2 Comments:
No problem. :)
by
Add a comment
Add your answer
Hannah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 73
