Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
90 Questions View all
PSP go wont turn on when charger plugged in
The PSP turns on and works fine but whenever I plug in the usb charger, the system turns off. The usb side doesnt even have to be plugged into anything, once I jack it into the PSP it will turn off. I set it to USB mode but thing works. The battery still charges though.
Add a comment
1 Answer
Chosen Solution
Are you talking about a cable? If the other end is not plugged into a USB port and the thing is shutting off, that would suggest the cable you are using may be bad - as in shorted. I would try another cable.
Score 1
1 Comment:
Okay thank you I bought three cables on amazon and apparently one of them worked. I assume yes it was causing the PSP to short.
by
Add a comment
Add your answer
Alejandro Tellez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 21
All Time: 333
