Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Wifi and GPS Problem
Well I dropped my iPhone 4 at&t in water and the mic for video and the wifi stopped working and my GPS started giving very vegue location services. Recently my mic started working but the gps and wifi stayed the same... Recently i took my iphone appart because the LCD connector came loose and i had to fix it... After reasembly i realized my wifi was working but very weak and my gps was the same... So i have two questions... 1. Where are the screws that ground the wifi ive heard they could be the problem and 2. Should i replace my wifi antenna or something else?
PS. I had my phone repaired at some shop and they lost some screws and they lost the pressure/connector thing near the battery connector if that makes a difference.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Check the screws around the EMI shield (the shield that covers the 5 connectors on top). That is your wifi antenna.
Replacing the 'wifi antenna' does not solve this problem as this is not actually the wifi antenna as many sites suggest but it is the GSM/GPRS/3G antenna instead.
Score 1
Add a comment
Add your answer
Richard Collins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 3,220
