HTC Desire 620 Android smartphone. Announced 2014, December. Features 3G, 5.0″ Super LCD capacitive touchscreen, 8 MP camera
14 Questions View all
Why phone is not charging from charger?
Hello all,
I have problem with HTC Desire 620g. This morning i tried to charge phone from charger adapter, and it`s not working. I tried with other adapters to also not working… When i tried only with USB-Cable attached on my laptop phone is charging. So the problem is, phone can`t be charged by charger only from cable attached to PC-or Laptop.
Thanks in advance,
Regards,
Goran
Score 1
2 Comments
@gorangiroud "phone can`t be charged by charger only from cable attached to PC-or Laptop." most certainly a bad USB charging port. Follow the advice given by the two answers.
by
No my phone is dead no on
by
Add a comment
Most Helpful Answer
Hi @gorangiroud ,
Did you use the same cable with the other adapters or did they have their own cable?
Presumably, you also tried connecting the adapters to a different power outlet? ;-)
Use a strong light and a magnifying glass to check the USB port on the phone, just in case it has lint trapped in the enclosure preventing a good connection. Also check that all the pins are there and that they are straight and parallel with each other.
If there is anything in there, DO NOT use a metal pin to try and remove it, use a vacuum cleaner instead to try and get it out or if necessary a wooden toothpick to gently pry it out.
Score 3
1 Comment:
No this is not the problem, i tried with same usb cable. Attached on charger it`s not working, attached on my laptop it`s working and it`s charging... Charger it`s okey i tried with my other phone it`s charging. Problem it`s probably from the phone. USB port from phone is working, it`s charging now but attached in laptop port.
by
Add a comment
Probably a bad charging port, you might need to take it in for repairs if you have tried absolutely everything.
Score 1
Add a comment
Add your answer
Goran Milev will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 246
