0
Score
Avatar
Margaret
Asked
Flash is not in sink with picture
History
When I take a picture the flash goes off, how ever the image looks like no flash was used, I went to menu reset but this did not work any suggestions? is this a setting issue or do I need to take the camera to a repair shop.
How far away from the subject were you.. There is a fairly limited range on these. Are all images dark? Including ones taken in natural light?
pollytintop,
Post Answer
2
Score
Avatar
oldturkey03
88.3k
Answered
PermalinkHistory
After reading through the manual page 94-104 I think it might be a problem with the automatic settings. I would most certainly try to adjust the settings before taking it in for service. When your pictures are underexposed, Nikon recommendations are
If sensitivity (ISO equivalency)is under 1600, raise sensitivity.
• Use built-in Speedlight.
• In mode:
S Lower shutter speed
A Choose a larger aperture (smaller f/-number)
Just in case you've lost your manual, it is available here Of course once you have exhausted your option you may have to take it in for service of the flash. I suppose you could try a horseshoe flash as well. Good Luck and let us know if your pictures get illuminated.
0
Score
Avatar
dpnsan
Answered
PermalinkHistory
This can happen if your flash is set to commander mode. Make sure that the flash is set to iTTL mode.
Add Your Answer
