First generation, based on the Ford C1 global platform.
35 Questions View all
Bell housing bolt patterns at Vs mt
My 2006 Mazda 3 threw a rod. I'm looking for a replacement engine. What I need to know is if I can get an at engine for my manual car and just swap the flex plate for the flywheel. I've heard rumors that the bell housings are different. Any help would be greatly appreciated. Thanks.
1 Comment
Ok awesome thank you so much.
by
Add a comment
1 Answer
Chosen Solution
As long as you get the same motor then it should just bolt up , doesn’t matter if it was auto or standard . you will have to change the flywheel ,just use your old one . you will also need the spacer plate for the starter from your old engine (depending on the year) as well
Score 3
Add a comment
Add your answer
Luke Jensen will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 19
All Time: 147
