Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
459 Questions View all
Orange LED turns on for 5 seconds then shuts off when plugged in
My 3DS has been doing this since today, whenever I try to plug it in to the charger, the Orange LED turns on for 5 seconds then shuts off. I can't even turn on my 3DS either. This is the red 3DS model from 2012. I checked the charger for frays but it works fine. What do I need to do? Order a replacement battery? Probably replace the whole thing?
Add a comment
1 Answer
Most Helpful Answer
Hi!
Was the battery completely discharged when this occurred? If so, try removing the battery, press the power button, plug it in for a moment and insert the battery (while it’s unplugged). You can also try removing the battery, plugging it in and reinserting the battery while plugged in.
If this does not work, I would start by replacing the battery: https://amzn.to/2OElIIh
Score 3
1 Comment:
Yes, this worked for me. I removed the battery while it was plugged. Then after replaced the battery the blue light went on and it powered up (finally!). Thanks!
by
Add a comment
Add your answer
Ian Devilibiss will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 142
All Time: 5,276
