The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
127 Questions View all
Stick drift persists after adjusting the sticks
Hey guys! I've been having bad upwards stickdrift on my right stick, so I took it apart and adjusted it to nearly completely remove it. It was fine. A bit of tiny downwards drift, but barely noticeable. Not long after, the drift has returned. I going to have to rip it apart and asjust sever times a day, or am I just doing it wrong?
2 Comments
Which model is it?
by
Sorry, I should have specified. 1708. The white one.
by
Add a comment
Most Helpful Answer
You can try cleaning the stick with 99.5% isopropyl alcohol, this has helped me with the same issue in the past, just dab it in with a Q-tip, and clean.
Score 1
5 Comments:
That was the first thing I tried. Before I tore it completely apart to adjust it.
I'm also getting double inputs on YouTube and Xbox dashboard of that helps.
by
Hm. Hard to tell, with the double inputs, did you by chance get the controller wet? or spill anything on it?
by
No, not that I know of. The double inputs seem to be linked to the control stick though. Whenever I adjust it to remove the drift, the double inputs go away, but they return as soon as the drift does
by
Could it be the sensor that I've been adjusting? If I put a new one in there, might it work normally?
by
A new sensor might fix the issue, however, be careful with the soldering. If there is damage to the logic board of the controller, it will persist.
by
Add a comment
The way plenty of people fix stick drift (including myself) includes the following.
  • Cotton Bud
  • Rubbing Alcohol
  • Controller
  • Wet the cotton bud w/ the RA then tighten it up/ squeeze the end, reapply RA then rub it all around the joystick as hard as possible
1 Comment:
what the heck is a RA?
by
Add a comment
I just fixed this on my elite controller and the way i fixed it was by separating the up and down green piece a little. Hard to explain but after you get your controller apart there are 2 green pieces. One for up and down the other for left and right. My conclusions is that the piece is worn out so it's loose. Separate the green piece on the right just a little bit so the black prong on the side go in a little. This worked for me and nobody told me about it
1 Comment:
Can you use the lens cleaning wipes because it says it contains isopropyl alcohol so can I use that
by
Add a comment
Add your answer
Mark Whittaker will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 23
All Time: 7,187
