PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
390 Questions View all
How do I fix my controller stuck on G on keyboard?
So basically I got this pre owned controller and when I go to type it glitches and stays on the G button, no matter what I do. I tested out the controller in-game and again, it spams certain inputs. I have bought a cheap wired controller and it appears that the problem was the touchpad AND the L3 and R3 buttons. So my question is how do I fix this and is there an option rather than purchasing a controller. Also is there a way to plug a headphone jack into the PS4 if there is no way to fix.
Score 3
Add a comment
Most Helpful Answer
Repairing the controller in this case sounds impractical. I would just buy a new controller.
There is a reset button on the back of the PS4 controller you could try.
There is no way to connect headphones to a PS4 directly, only through the controller.
Score 1
1 Comment:
you can absolutely plug a mic and headphone in the usb plug of your ps4 and a adapter that you plug them in , thats i plug my headset with my mic
by
Add a comment
i think you have to get your controller fixed or try to fix it your self and you would have to open the whole controller
Add a comment
Restarting the PS4 usually fixes this issue, as rebooting any device fixes most issues. Do note that the bug will reappear after a while. I have this same exact issue with a controller I brought a month ago and restarting the device is the cheap way to do it. If that doesn’t work, reset the PS4 controller, which is a small button underneath the L2 button. You might need a paperclip or a mechanical pencil to press this button.
Add a comment
I did all of this and none of it worked. I tried forgetting and reconnecting the controller restating the game and updating it.
Add a comment
Add your answer
Josef Baydemir will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 133
All Time: 11,843
