Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Questions View all
Ipad 2 does not charge even do the charging dock has been replaced
I am trying to repair an Ipad 2. The original issue was that it was not charging because it falls down.
In the first review, the charging dock looks broken from the outside, so I proceed to replace it.
But now, with the new dock, the Ipad still not charging. (there are no signs of the charging icon and it does not turn it on when the charger is connected)
When I connect the charger, it seems not to do anything.
The LCD works, the Home button works, but there is a problem with the Power button.
It does not work when pressing it.
Some ideas or where shuold I review?
Add a comment
1 Answer
Chosen Solution
It is possible that the replacement flex you installed is also defective; small parts tend to have higher failure rates. Otherwise, closely inspect the connector on the logic board.
Does it get recognized by iTunes when you connect it?
If it still won't charge but is recognized by iTunes, then it may be an issue with the actual charge circuit.
Score 2
4 Comments:
First of all, thanks for your answer.
Answering your questions, the iPad is not recognized by iTunes when connected.
But I also notice that if I left the iPad charging the charging icon does not appear, but the iPad charge in a very slow way. (I left it all the night and charge like 50% more)
Do you think that the flex replacement is defective? Or should I review something else?
Thank you very much
by
How are you charging the iPad? Via a computer, a small charging brick (like the iPhone) or the larger charging brick?
by
With the larger one.
by
Use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows). It will tell you what the health of the battery is. Anything less than 70% of design capacity will require replacement.
by
Add a comment
Add your answer
Diana Vargas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 67
