Toshiba Satellite C55-A5281 - 15.6" - Pentium 2020M - 6 GB RAM - 750 GB HDD - US
2 Questions View all
White Power LED, no fans, screen, or other signs of life
Power LED only shows after pressing the power button with the battery in; not with the charger alone. No charge LED when plugged in. Have changed RAM and switched seats, unplugged and re-plugged all ports on the mobo. Any ideas? The laptop was received after someone attempted to replace the bad screen and it would not respond after. No signs of water damage.
Add a comment
1 Answer
Try an External Monitor to check that at least the Laptop is POSTING. Try the VGA Port, if nothing shows up, try to switch the output to the external monitor using the keyboard key. Let’s just hope that the screen is dead no damage to the Internal Motherboard. :)
Add a comment
Add your answer
pcm will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 149
