Released August 2014. A 16.0 MP point-and-shoot camera with a 3.0 inch LCD monitor.
7 Questions View all
How to return a part of a graphic object?
I was editing bulk graphics in AutoCAD when a crash occurred. I just unloaded my photo-work done the day before, into the program for further processing and overlay, but after a failure in AutoCAD, I now do not see a few photos. This is impossible, because I didn’t delete them accurately, they combed it out on their own.
Add a comment
1 Answer
Can you view the file here, using Autodesk's online file viewer? If not, then it's probably corrupt.
• Go into the same folder as the DWG file, and look for the same named file, but with a .BAK file extension (You need to have file extension TURNED ON).
• This is the last save before your last save.
• Then rename that file from BAK to DWG and try that one.
• If that doesn't work, then go into your %temp% folder (in the address bar of Windows Explorer, type in %TEMP% and press enter).
• Sort by date and look for a file name similar to your original file, but with a .SV$ file extension.
• Rename that to .DWG and try it.
• This is your last Autosave file (it may not exist)
• If that does not work, look for the same named file in the %TEMP% folder with a .BAK file extension.
• This will be your next to last autosave file. It may not exist either.
• If it does, rename dwg file and try to open it.
Source that tell you how to repair dwg file:
https://knowledge.autodesk.com/support/a...
http://www.thesourcecad.com/recover-dama...
http://www.dbf.repair/
Add a comment
Add your answer
MillieDean will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 6
All Time: 61
