0
Score
Avatar
charlie61561
Asked
iPod will not turn on even when connected to charger or computer
History
gen 1 nano ipod shows no life with or without being connected to wall charger or computer. At one time display came up for 3-4 seconds then turned off when connected to wall charger. Now no sign of life what so ever!
Edited by
Post Answer
0
Score
Avatar
oldturkey03
59.5k
Answered
PermalinkHistory
charlie61561, the first thing I would do is to replace the battery for sure. It is definitely at the end of its life span. While you do that also check all the connections and cables for corrosion and debris. Clean it well. The dock connector needs to be cleaned of all debris, since it is providing the actual life connection for your nano. Use a wooden toothpick and/ or some compressed air if you have it. Check for bend contacts and corrosion as well. After that, re-assemble and evaluate for further errors if any.
Installing iPod Nano 1st Generation Battery Replacement
iPod Nano Gen 1 Replacement Battery
Product Image
Installation requires soldering / 400 mAh — 32 available at 14.95 each.
Add Your Answer
