0
Score
Avatar
Paul
Asked
Noise problem: Left fan replaced, problem persists
History
Hello everybody,
I was having big noise problems coming from the left side of my Macbook Pro. Grinding stuff, highly uncomfortable. First I opened the laptop and added some lube to the left fan. The noise disappeared for a couple of hours. I then proceeded to replace the fan, with one from ebay, following the instructions from this website.
After doing so, the left (new) fan continue to produce some noise, although a slightly different one than the one before. Noise goes crazy and suddenly stops. Now iStat says that the left fan ain't spinning. I did a reset on the SMC but still, left fan runs at 0 RPM. Noise of course, disappeared. :P
PS. I'm not sure if the fan is effectively not spinning, I believe I'm getting a low humming, though a different one that the one coming from the right side.
THANKS!!!
For information, left side feels hotter than the right side.
Paul,
Post Answer
Score
Avatar
mayer
121.8k
Answered
PermalinkHistory
The problem with buying a used fan or an ebay fan is that it's probably as old as the one you're replacing. On this part I much prefer new parts. Here are new ones: MacBook Pro 15" (Model A1150) Left Fan
http://www.powerbookmedic.com/MacBook-Pr...
Product Image
Replaces a defective or noisy fan — 24 available at 49.95 each.
Hello Mayer, Thanks for your answer. I did replace it with a new fan. It was in the description and it did look new. :S
Paul,
How's it working?
mayer,
Latest and greatest: I turned on the computer with the case open. "New" fan not spinning. Reconnected old fan with noise issues and it spins. Stupid fan! I'm going to return it. I lubed the old fan but problem persists... at least I know now.
Paul,
Lots of info on the web for what to use and not use to lube. I like graphite.
mayer,
Add Your Answer
