The PSP 3000 was released in the U.S. on the 15th of October 2008.
92 Questions View all
Power LED comes on, but turns off after 15 secs.
I have a friend's PSP3001 that will not turn on. The battery is charged, and when I turn it on the power LED turns green for 15 seconds and then turns off. The screen doesn't show any signs of powering up, and I cannot hear any sounds from the speaker or the headphone jack. He swears he wasn't trying to change/update the firmware, just hadn't played it in a while and could not get it to turn back on.
Does this sound like bad connections or is it bricked? I was hoping to have some clues before opening it up.
Thank you in advance.
Score -1
Add a comment
1 Answer
Chosen Solution
It honestly sounds like its bricked. If it is a bad connection, then you should be able to see it when you open it up. Not having sound, video, or even a boot up (assuming its not bricked) suggests a loose ribbon cable or bad fuse. Let us know what you find when you open it up. :)
4 Comments:
I opened it up slowly, checking for any signs of water or debris damage, but it was clean. I checked the connections before I disconnected anything and they were all tight. I metered the fuses that I found and they were good. I am guessing it was bricked. He isn't the type to jailbreak his own things, so I don't know what would have happened, but now he has spare parts for his new PSP; he was able to get the same model.
Thank you for your help.
by
You can also brick it by interrupting a normal firmware update; i.e. disconnecting power while installing. At least you got something nice out of it.
by
I have exactly the same problem only difference is that I get the intro sound the screen flashes for 1 second but then shuts off. I have to mention that I cant turn it on by the power button. This is weird I just plug the power in and then quickly unplug it and it turns on which in turn runs off the battery but shuts off after 5-6 seconds. What can I do about it ?
by
@letty...you may get better answers if you ask your own question. Give as much detail as possible. Right now your question is listed as an answer to a very old question.....use the "ask a question" button below the device picture.
by
Add a comment
Add your answer
bugman will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 8
All Time: 7,972
