The Huawei MediaPad M2 is a full-sized Android tablet released in February 2016. Includes models M2-A01W (Wi-Fi only) and M2-A01L (Wi-fi/3G/4G).
4 Questions View all
I can do with the error that I met on my device in CorelDraw?
Recently, I did not fail to complete important work. Several files opened in CorelDraw with errors - a valid workpath path was not found. And I have no idea how this could happen. I hope for your help. Perhaps someone here has already met with a similar problem.
Add a comment
1 Answer
There are many variants of coreldraw file recovery, but the most easiest are the following...
By guide
Corel makes a .BAK backup file that has the same name and is usually located in the same folder as the original file, but can also be located in the /Programs/Corel/Programs/Draw folder.
When a file is corrupted or otherwise damaged, find the .BAK file, open it, and copy it (save as) over the original corrupted file.
Or by articles, tips, etc...
https://support.corel.com/hc/en-us/artic...
Add a comment
Add your answer
NoelleFoley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 383
