Why does my dvd player horizonal roll when I try to play
when i try to play dvd the horizonal roles
If the picture is rolling, that indicates a problem with the "Horixontal hold" of the TV and is not likely a problem with the source which in this case is the Bose system. I have to assume that the TV is connected with either a coax cable or an RCA style video cable. A digital connection such as HDMI is not likelyto have this problem. This is a problem with the display and not the source. Please update this with more information about how the TV is connected and the model number of the TV.
Dan
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 7
All Time: 42
Hi,
Was it working OK before with the TV / DVD player setup you have now?
How is the DVD player connected to the TV, HDMI, Composite video (yellow, red, white cables) Component video (red, blue, green, red + white cables)?
Have you tried it, with the DVD player connected to a different input "type" on the TV to see if it works OK? e.g. if HDMI try Composite (AV) video connection between the two.
Have you tried it with the DVD player connected to a different TV to prove where the problem is the TV or the DVD player?
by jayeff
