Repair guides and support for the Toshiba Satellite P850/P855 laptop series.
5 Questions View all
Screen went black after battery got low
Low battery came across screen but before I plugged in computer screen went black. This has happened at least 2 times recently. And it took trying to turn on 3 plus days before screen came on. Tried the function F8 shift and power over 6 times did not work. What to do ?
Add a comment
1 Answer
Most Helpful Answer
It sounds like your computer automatically went into hibernate mode when the battery got real low, and you couldn't get it out of hibernate. If you disable auto-hibernation, you will eliminate this from happening in the future. Keep in mind that by disabling auto-hibernation, when the battery runs out the computer will just "crash" - it will simply turn off if there is no power. The good thing is, it won't be stuck in hibernate mode, because it never went into hibernate. But you will lose anything you were working on and didn't save before the computer ran out of power. To disable auto-hibernation, go into Control Panel and change your power options.
There is also a power option which will turn the display off when the battery gets down to a certain amount of charge. You can change that option to keep the display on as long as there is any power at all in the battery. Or you could change it to where it dims the screen rather than turning it off when the battery is run down almost all the way.
Score 1
1 Comment:
Thanks, very helpful
by
Add a comment
Add your answer
Janice Watts will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 1,284
