Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
What is the Display IC chip?
Hello everyone,
Everything is in the title of the question.
Is this the chip that handles the display panel. Or it does a different function?
Thank you in advance for your replies.
Score -1
Add a comment
1 Answer
Chosen Solution
I thinks that it is part of the System on Chip Samsung S5L8900 as outlined here and further explained on here
device 0 (17 rec)
"device_type" => 0x757063
"function-cpu_idle" => (8) "\x128N@\x00Iupc"
"reg" => 0x0
"bus-frequency" => 0x0
"peripheral-frequency" => 0x0
"state" => (8) "running\x00"
"timebase-frequency" => 0x0
"memory-frequency" => 0x0
"fixed-frequency" => 0x0
"compatible" => (21) "ARM,1176jzf-s\x00ARM,v6\x00"
"interrupt-parent" => 0x403BD0
"name" => (5) "cpu0\x00"
"clock-frequency" => 0x0
"function-ipi_dispatch" => (12) "\x208;@\x00DIPI\x04\x00\x00\x00"
"interrupts" => (8) "\x04\x00\x00\x00?\x00\x00\x00"
"cpu-version" => 0x0
"AAPL,phandle" => 0x402310
as well as a PowerVR MBX 3D graphics processor:
device 0 (10 rec)
"device_type" => 0x78626D
"clock-ids" => 0x2
"reg" => (8) "\x00\x00\x00\x03\x00\x00\x00\x01"
"power-gates" => 0x2
"clock-gates" => 0x13
"compatible" => (13) "mbx,s5l8900x\x00"
"name" => 0x78626D
"interrupts" => 0xC
"AAPL,phandle" => 0x40C570
check further here and on here
This info from here
Paired with this CPU is a PowerVR MBX-Lite GPU core. This GPU, like the CPU, is built on a 90nm process and is quite simple. The GPU does support hardware transform and lighting but it’s fully fixed function, think of it as a DirectX 6/7 class GPU (Riva TNT2/GeForce 256).
Hope this provides you with the information you needed.
Score 2
1 Comment:
Brilliant research! Saw this q late last night and gave up when brain went zzzz after a quick google
by
Add a comment
Add your answer
carlitostyle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,316
