Repair guides and support for all types of batteries.
74 Questions View all
Is there a discharging device for this gopro karma drone battery?
Is there a way of building a discharging device for a gopro karma battery (gopro karma is a drone) like a bulb that will discharge the battery. The connectors are different and I have not seen anything about it. There are other batteries that has a simple connectors but this one is a bit different.
Update (05/15/2018)
The purpose of having a discharging device is to discharge the battery to a certain voltage so as when you store the battery, the battery life is extended. Of course you discharge it when you have to store the battery for a longer period of time. I have seen some attachments to other lipo batteries to discharge it but I have not seen one for this particular battery. So, is there one out there?
Score 1
1 Comment
Just curious ,why discharge it?
by
Add a comment
1 Answer
Most Helpful Answer
You could always use the karma as a discharging device and run the karma for a few minutes before removing the battery and storing it on a shelf for an extended period of time. Otherwise, you could try interfacing to the battery connector and plug in a ~15v fan to discharge the battery.
Good luck!
Score 2
Add a comment
Add your answer
edbaradi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 250
