Antenna on the handheld part broken
First the casing fell off and now part of the the actual wire of the antenna broke off (on the handheld part). Any way to fix this?
Score
0
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 16
All Time: 198
Casey Morlet possibly. Looks like they are using a lot of glued components etc. Any chance you can post some images of what broke where on your device? It will help us to see what you see. Use this guide Adding images to an existing question for that.
by oldturkey03
oldturkey03....can't right now, sorry...my husband has it allll taken apart and yes, you were right about glued components. What a mess. Basically if you look at the product picture on the right of this post, the gray outer cracked off at the top of the handset. Then the wire was exposed. It is covered in a metal cylinder until the last inch, which is just coated wire...the coated wire broke off right above the cylinder. If you retouch the wires, it works, so I know it's not completely busted. Taping the wire back together is spotty.
by Casey Morlet
