The LG 60LM6450 is a 60-inch LED television released in 2012. It supports 3D video with glasses at a resolution of 1920x1080 pixels.
77 Questions View all
Coax cable broke off on back of tv
I have basic cable my coax cable port on the back of the tv broke off is there something i can use to convert the hdmi or another part of the tv so i can use the coax cable? Or is it repairable?
Add a comment
Most Helpful Answer
Hi, @geko1986 ,
You may be out of luck.
HDMI cannot tune into any TV channels. (FTA or cable TV). It is not a tuner.
The co-ax port is part of the digital tuner module on the mainboard. This is a sealed unit and difficult to repair.
If you wish to continue to use the TV, either replace the mainboard or get a compatible box which connects to your cable service and connect via HDMI from it. (if you mean when you say that you have "basic cable' that there is a co-ax cable FTA antenna lead into the TV then connect it to a HD set top box and tune into the channels using it and connect it to the TV via HDMI)
Score 1
Add a comment
there is an HDMI-Coax plug converter. you can try that.
Add a comment
I had the same problem. Repairing the coax plug is difficult for an HD tv, most of the videos on YouTube are for older tvs - see link here https://www.youtube.com/watch?v=S9v-dUyz... . Buying an external tv tuner, sometimes referred to as a converter box, is probably the best answer (see jayeff’s answer). I bought this product https://www.amazon.com/gp/product/B07VNV... and it seems to work just fine for getting over-the-air tv broadcasts (not cable tv).
1 Comment:
Were would I get the coaxial input for my tv
by
Add a comment
Add your answer
Geko will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 48
All Time: 6,679
