One of Sony's 13.3" models in the 13A multi-flip laptop line.
3 Questions View all
Maintain power to Laptop when changing battery
I have a Sony VAIO SVF13N17PAB, and just received a replacement battery [VGP-BPS41] from the Sony preferred parts supplier. Do I need to maintain power to the laptop when replacing the battery? Also will I lose data/reset to factory settings when the battery is removed? Thanks Scott
Score 1
Add a comment
1 Answer
Most Helpful Answer
Do not change the battery while it is connected to power. Turn off your computer, then take out the battery and finally plug in your new one. No data is stored in the battery so don't worry about reverting to factory settings.
You should always power off your device when you replace a part.
Score 2
Add a comment
Add your answer
Scott Evans will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 217
