Repair guides and support for LED, LCD, HD and other Vizio TVs.
934 Questions View all
Can you resize the info window?
I have had a 55" Vizio for about 10 years and have absolutely loved it. We recently moved and bought a 50" Vizio. The info bar on the new TV is so small we can't see it. We can barely see the channel it is on or the info about the show. Is there a way to make that larger like the older TVs?
Score 3
6 Comments
Hi @kreeves11674 ,
What is the model number of the TV?
by
It is a D50-E1
by
It is a D50X-G9
by
If you don't mind the zoom picture it also works on the text
Not the best answer but the only one I found
by
Same issue can barely see the Channel number it's so small. Can't you do a software update and fix this?
Model # D40f-G9
by
Show 1 more comment
Add a comment
Most Helpful Answer
Hi @myextra99,
What is the signal source of the TV?
Is it from the antenna or from a “box” of some description?
If from a “box” have you checked the settings in the box to ensure that things like aspect ratio and other settings that affect the picture are OK?
Score 2
4 Comments:
From an antenna direct to the tv
by
Hi,
The user manual - see p.20 does not show the options but have you checked in the Picture Mode Edit setting menu to see if there are any settings that allow you to resize what is displayed?
Has the problem always been there or has it just occurred?
If just recently occurred try resetting the TV back to factory default and check the result. See p.37 of the manual
by
I checked the picture mode and nothing that worked. I just got the tv a couple weeks ago and probably should send it back if it was not so much trouble. In factory settings it was as it is now, way too small. I checked other web sites and it seems there isn't a fix! Whoever designed it sure must have super power eye sight!!. Thanks for trying
by
Hi,
Try contacting Vizio by email about the problem. Be polite but firm that this is not good enough.
Ask if there is a firmware update that may fix the problem or if the problem can be passed onto their technical department or if their technical department can contact you about it
Vizio states that the TV firmware is updated via the internet using settings in the TV (there are no longer any manual updates by downloading and installing it yourself) which doesn't help if the TV is not connected to it.
I've found that a lot of companies respond better to emails, because they have to reply in writing rather than if you contact their customer service by phone where it appears that you are being fobbed off.
If they don't respond positively, return the TV and get another brand.
If enough people did this they might get the message.
Good luck
by
Add a comment
Hi @kreeves11674 ,
Can only suggest that you check that the aspect ratio for the TV is set to Normal (p.36 of the User Guide) and failing that try restoring the TV to its' factory default settings (p.38 of the User Guide - take note of the warning if you go to do this).
Here is a link to the User Guide for the TV.
Score 1
Add a comment
Hi kreeves, try turning on the zoom mode, it enlarges the text on the channel, so u can see the info better on the channel.
Add a comment
There is no fix. It’s built in. Zoom doesn’t work, factory reset doesn’t work
Here’s my fix. Move recliner close to tv!
Add a comment
Add your answer
Kevin Reeves will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 57
All Time: 7,432
