Multi colored vertical Lhmd bes
Multi colored vertical lines appear when TV is turned on - they disappeared after a few minutes but now remain longer and longer
Update (04/13/2018)
. This is a picture of the issue I have
Bakr Ragragui those are usually a sign of a bad panel. Since it used to get better when your unit warmed up it is possible that this is caused by a cold solder joint. You would have to take the back of and visually inspect the boards to see if you see any obvious damage like a bad capacitor etc. Post some images of your boards with your question so that we can see what you see. The main board is where I would check first. Please verify that your TV is a Samsung LN46A530P1FXZA
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 82
