Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
874 Questions View all
The iPhone 8 China-copy screen is not compatible with iOS11
iPhone 8 screen broken and replaced a cheap China copy screen. Everything works well until I upgrade the system to 11.3, the screen touch not work? Anyone know how to solve this issue? Is it a bug? (the screen can work well after downgrade to 11.2.6)
Score 1
Add a comment
Most Helpful Answer
I suspect 11.3.1 will fix this issue. 11.3 has broken a lot of things that should not have been.
Score 3
Add a comment
This is a known issue and reputable suppliers have contacted people about the possibility of the problem with the lower tier aftermarket screens which are fixed via a firmware update to the IC of the screen.
More info and source here:
https://www.reddit.com/r/mobilerepair/co...
Score 3
Add a comment
This problem exists for the cheap and high imitation screen produced in China. The system upgrade will cause all kinds of problems in the screen, such as screen, white screen and no touch function.
Add a comment
will using an apple screen or high quality aftermarket fix the problem?
or are the customers screwed? i fix about 20 a month and this could cause problems
Add a comment
Apple is adding software to ios updates that will detect aftermarket batteries, screens, possibly other components. There is no way to fight this right now. The only answer is to find used Apple parts. Any repair shops using aftermarket batteries and screens could be bit hard later when all your customers end up with boot looping iphones. If you then try to go to the Apple store and have them install a real Apple screen, they won’t do it. Any aftermarket parts installed will prevent them from doing any repairs at all.
Add a comment
Add your answer
Mandy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 510
