Released in early 2015, the Canon PowerShot SX530 HS is a Wi-Fi enabled, super zoom camera. This camera weighs just under one pound. Identified by model number pc2200.
18 Questions View all
Why does my camera shut off seconds after starting to record a video?
With a fresh battery and fresh SD card the camera will shut off moments after starting to record a video and say "charge the battery" I turn it back on and the battery is full.
This is such a frustrating issue and I dont want to spend hundreds to send it to cannon when the fix might be simple.
Score 1
5 Comments:
When you say fresh battery, do you mean you just charged it or did you just buy a new battery? Do you have a 2nd battery to work with?
by
All the batteries I have do photos fine, just not videos
by
Hi Rich,
SW asked if you were using a new battery. The batts you have may have internal resistance. They can give you enough current flow for a split second for a still pic but not enough continuous flow for a video. Try a new battery. If no success, it means there is a resistance inside the camera. I can't help you there.
by
Before taking any drastic or expensive action, check out all the connections and wiring from the battery to the PCB including battery contacts. A small amount of corrosion can cause a big resistance in very small components. Corrosion on the PCB can short between 2 components. You may need a magnifying glass to see it. Good luck.
by
Connection is fine, seems to be a common hardware error that happens to pop up right outside warranty range UGH
by
Add a comment
1 Answer
Mine was a 2013 model which would run the batteries dead when not in use.
This well-known problem 'developed' over time,,, of course, just as the warranty expired.
It is a nice camera for still pictures. Period. Remove battery after use.
1 Comment:
Mine does not do that, and same here, get the issue right after warranty , WHAT DO YA KNOW
by
Add a comment
Add your answer
RichManSCTV0 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 24
All Time: 1,137
