Released September 14, 2012, Apple's EarPod headphones are a new revision to their iconic white headphones. Model number: MNHF2AM/A.
59 Questions View all
Only works in one ear, very quiet unless I bend the cord a certain way
I got EarPods with my iPhone a while ago and I had them stored away, but when I tried to use them, only one ear worked but it was very quiet unless I bent the cord a certain way. This isn't the device, I used it on my iPhone, Mac and iPad. It's the headphones.
Is there any way I can fix this? My cat chews through most of my headphones but they look practically brand new, so I know she hasn't touched them.
I don't wanna spend $30 on a new pair of headphones, especially if there's a fix for this.
Add a comment
Most Helpful Answer
Hi Morgan,
It sounds like there is broken wiring or a bad connection. Try to isolate where the problem is by bending a section of the wire while holding the rest still.
If you are comfortable using a soldering iron for electrical repairs, you can search on Google for detailed repair instructions.
Otherwise, you can give these ideas a try:
If it is near the Earpod, a temporary fix may be to use a hot glue gun to reinforce and prevent the wire from pulling. If it is anywhere along the wire, you can try to make a "stent" by taping part of a toothpick against the trouble spot to reinforce and relieve strain.
Good luck and happy repairs!
Score 3
Add a comment
Try putting the plug in the ear phone jack and if it’s bent put them in up to where it’s still straight and bend it back to place
Add a comment
Add your answer
Morgan will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 15
Past 30 Days: 34
All Time: 3,491
