Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
302 Questions View all
Turn signal causing brake light to go out
Driver side brake light goes out when I use the left turn signal, it comes back on after I do the right turn signal then the left again. I replaced the brake light switch, flasher relay, and both back light circuit board and bulbs. Is it possible that it could be the turn signal switch on the column causing this issue?
Add a comment
Yes, it's possible the turn signal switch is failing, but it's most likely still in the turn signal flasher. The right side bulbs might have enough resistance to heat the flasher and get it working so when you switch back to the left side the flasher continues to work. Before you buy anything, try switching the turn signal flasher with the Hazard flasher. That flasher will flash even with no bulbs. The fact the brake light goes out is showing the turn signal switch is working to some degree. It switches the power coming from the brake light switch and sends it through the turn signal flasher. If switching the flasher works, try using a TRIDON #EL12 flasher unit.
If it only happens when you have your foot on the brake, then you have a ground issue.
Also if you installed any (front or rear) of the turn signal bulbs with LED bulbs you need to install a Flasher designed to work with the LED bulbs (like a Hazard flasher). The LED bulbs draw extremely low current and will not heat up the factory designed #552 turn signal flasher.
Hope this helps
1 Comment:
I had the turn signal switch in the steering column replaced and that fixed the brake like problem.
by
Add a comment
When I push my brakes my rear signal lights come on what is that I change the bulbs signal switch and wire harness check all ground to
Update (02/19/2022)
I checked all of that and it didn't work turns light still coming on when I hit the brakes
Add a comment
Add your answer
Greg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 5,376
