The second generation (KK) Jeep Liberty, a compact 4-door SUV that restored the classic sharp lines of the original Jeep styling.
19 Questions View all
Why will my Liberty not start after running out of gas?
Liberty ran out of gas. Added gas and will not start. Put in new fuel pump, changed plugs, checked compression, checked coil, checked ASD relay and unplugged compressor. The plugs helped a little and it tries to start but it will not. Check engine light blinks 10 times when you turn the key on. Manifold absolute pressure or barometric pressure circuit high. Po 108 code. Random multiple misfire. Po 300 code Please help.
Add a comment
1 Answer
This information is for your PO108 code code
Since you have tried everything else, I would try your crank angle sensor.
Add a comment
Add your answer
Jen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 278
