The Toshiba 40PB200 is a 40-inch flatscreen television in the PB200 series. It was released in 2012.
36 Questions View all
TV LCD Toshiba 46wx800
good day
I have a toshiba 46wx800u TV, which was cracked in several parts the glass cover of the screen. The TV works well. I want to know if you can take off and change the crystal. and how it should be done.
Thank you very much
Add a comment
1 Answer
Most Helpful Answer
@antoniolg going by your description alone, it sounds like a bad LCD. The only way to fix that is by replacing the complete panel. Here comes the bad news, panels that size are rarely available and will most likely cost more than a new tv (if available). You can pof course try a search based on the label that is affixed to the panel itself and see what you come up with. Another possibility would be to try to find the same make and model TV as yours ut that is broken differently. Then harvest the panel from that. Of course this is based on your description. To verify this, post some images of what your screen displays with your question so we can see what you see. Use this guide Adding images to an existing question for that
Score 1
Add a comment
Add your answer
antonio lopez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 121
