The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201 Questions View all
Why isn’t my phone turning on?
i didn’t do anything i just turned my phone off and then after when i tried to turn it back on it stayed off and when i put my charger in it doesn’t say it’s charging. i haven’t dropped it or anything. what should i do?
Add a comment
Remove Battery and then plug into charging cable. Try and power up. If this works the Battery is dead and needs to be replaced.
Add a comment
unfortunately the phone will not power on without a battery in. Try replacing the battery. If that does not work you most likely have a logic board problem, which is common over time with a phone that old.
Add a comment
Add your answer
urie diculous will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 5
All Time: 55
