Designed in 2005 and released for the first model year in 2007, the GMC Yukon is a five-door SUV. It is a rebranded version of the Chevrolet Tahoe, both of which are designed by General Motors.
13 Questions View all
How do I change the oil pressure sensor in my 2011 GMC Yukon
What is the easiest way to change the oil pressure sensor in a GMC 2011 Yukon I can't afford to pay 400 dollars to have a 30 part put in and I'm pretty good with tool I just don't know how to do this or where it is
1 Comment
If Cartalk where still I'd direct you to those guys.
But they're not. @jimfixer or @jayeff may be able to help.
by
Add a comment
Chosen Solution
Depending on the motor thats in the truck it can be a difficult job . you will need a special socket to do the job. This video will help some . Its a very tight spot to do. On the 6.2 it requires you to remove the intake manifold so it can start to rake in a lot of time. It is a job that could be a little easier if you have small hands . Hope this helps
Score 3
Add a comment
Can be done without removing intake
Add a comment
Add your answer
nicole parsons will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 69
All Time: 9,037
